Wire backup camera - help
I got an aftermarket backup camera and need to route a wire from inside the cab to the license plate. What is the best way to route the wire out of the cab? Is there a plug somewhere in the cab that can get under the truck?
Thanks!
There’s a lil grommet under both the driver floorboard and passenger front floorboard. Both in the same locations. You’ll have to pull the carpet up but it would be just where your left foot ( driver seat) rests while sitting. Vice versa for passenger side. So it’d be your right foot.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,155 Guests (See full list)
