about a week ago my truck started idling really ruff. and it has also started throwing soot out of the exhaust. the only thing i can think of is that the injector cleaner i put in messed up my cat. does anyone have any ideas.
If it's a 92 Blazer, and you have a 350...It has throttle body injection, not fuel injection. Unless you or a previous owner installed it.
I would start with electrical (plugs, wires, distributor etc) if you are idling rough...My 1st guess would be the distributor....It can cause your timing to get fubar and cause the smoke, pinging, bad idle etc.
Is it throwing an SES light when you hammer it?
You gotta share a little more :sigh::)
Go get your code read. Autozone, and most of the others will do it for free. Just punch it a couple of times in order to get the light to come on before you get there, and leave it running until they read the code.
If it's laying down, blowing smoke, and you are throwing an SES light, my first guess would be your anti-knock sensor. Passenger side, down by the starter. $5.00 part. :)
my truck is still shacking. i havent touched the sensors yet. but do you think it could be the cat. my truck has been spitting out some soot. i dont know i just need to find some time to fix my truck
The anti-knock sensor reads the air coming out of the exhaust, and sends this to the computer for analysis.
If it's malfuntioning, it tells the computer bad things, and f'd-up stuff starts happening because the data the computer is basing your fuel/air/timing/etc on is erroneous.
Thats the best my pea brain can explain it. I'm no ASE expert.
You could also be right in that your cat could be bad.
I still say to go to a parts store with a code reader (call in advance, most perform this for free), and show up at the store with the SES light ON, and let them hook up. They will most likely be able to tell you right off if it's a sensor (O2, anti-knock, etc).
Just out of curiosity, have you checked your PCV valve lately?
One other thought occured to me. Right after cleaning the fuel injectors on my S-10 Blazer one time it started running with the shakes. Turned out a piece of carbon had come loose and got stuck in the EGR.
Hope you get this solved soon.
Mike
Grand Haven, MI
  • 4 weeks later...
Try some Fuel Injector cleaner and DRUM it out on a highway free of police and cars! Sounds like its got dirty injectors to me. The alternative I can think of is have it torn apart and cleaned and perhaps an injector is bad.
You may be getting bad gas as well. Try a dose of higher octane at another station.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
    • Got this yesterday out of nowhere. Truck is a 25',6.6 gasser with 8k miles.  Only semi anomaly is that the truck had been sitting, uncranked for 6 days. Elec Stability Control showed immediately upon cranking, not while driving. No drivability issues, just the message. Battery didn't seem to be weak when cranking over.  I drove it, killed it, let it sit a few hrs with no avail.  Truck is 100% stock. No damage.
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
    • I was unaware of that, thanks for updating me.
    • Yes.  The 2.7 Turbomax has Active Fuel Management.  It is NOT the same as the V8s.  Totally different system.     Here is an article from GM when the 2.7 came out explaining the cylinder deactivation and the valve lift system.  Starts at the section called "SCS Valvetrain":   New Turbocharged 2.7L 4-Cylinder Engine Powers Full-Size Trucks – TechLink         This is an internet myth going around.  It was alleged that some 5.3s had this mystical 8th digit of the VIN as an "E" which somehow meant it had a new one year only 5.3 that didn't have DFM.  The writer of said article and the person that made the claim conveniently can't count because they posted the VIN.  The 8th digit was a "D" which meant its still the 5.3 with DFM.  The 9th digit of the VIN was an "E" and the 9th digit isn't the engine code.  At all.
