2004 Chevrolet Avalanche w/ Bose system
I have a 2004 avalanche with the Bose system and one day the radio went off. Well about 3 times a year the radio will kick on but turn right back off typically within 5 minutes+. I checked all the fuses those are fine the rear radio works when headphones are plugged into it like it’s supposed to so it can’t be the radio head? I made sure the wires in the back of the radio are on properly and  the wires on the amp as well. Can’t be the speakers bc they all 4 can’t just give out ALL AT ONCE and then ALL turn back on at the same time working like normal every once in a blue moon. But like I said. All wires are pushed in tight, Rear radio works, turns on every once in a while for a couple minutes so it can’t be a fuse because once a fuse is blown there’s not brining it back to life, if there was something wrong with the amp then the rear radio wouldn’t work either right? Also radio turns on just fine. If it could be a loose wire besides the ones on the amp and back of radio where all could I look?
    contrabombarde
    contrabombarde
  • Who's Online   4 Members, 0 Anonymous, 1,395 Guests (See full list)
    • Some clarification may help with some of these issues.   - Rev Industries is/was the division of BAK (now Realtruck) that makes covers under the OEM names.  So if you see one with a Ford logo on it, or if you are buying the GM Accessories cover, you are essentially buying a BAK G2 cover with different branding.   - Rev Industries now markets under RealTruck "Advantage."   - As of May 1, 2025, the Advantage covers now have a 5 year warranty.  Anything before that was a 36/36K warranty.   - Parts for the covers are available from Realtruck or BAK.  The email address to reach them is [email protected] or you can call them at 818-365-9000   - If the entire cover has to be replaced, you have to go through your local GM dealer.  Service dept opens an RO, notes the damage and submits it as a warranty claim.  Keep your paperwork handy so they can confirm when you purchased it and it's within the warranty timeframe.  Once the warranty claim is approved, Parts orders the replacement cover.  When it arrives at the dealership, service will remove and install the new one for free as labor is included under warranty.   - The Advantage covers are not the latest and greatest Gen 3 covers.  They still use the old school clamps, elevator bolts, etc...If you want the newer technology, consider buying your cover in the aftermarket world.  That way, if you have an issue you can deal directly with the manufacturer.   - Finally, RealTruck has a program with many of their authorized dealers that doubles the warranty to 10 years if the authorized dealer does the install.     Hope this helps.
    • Welcome to the group!  My '22 just crossed 150K miles.  Runs perfectly.  Oil pump belt will be done in the next 30 days or so and onward hopefully for another 150K.  Love the truck.
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
