Lucas oil additive
Black02Silverado
I found this interesting while I was on bobistheoilguy.com forum. Thought that a few might find it interesting as well. This is the link to the forum part. Just click on the link in Bob's post and check out what happens to Lucas.
Info on Lucas
The posts in the forum are some interesting reading. Kind of makes you wonder just exactly what is going on in the engines with oil additives. :thumbs:
Thats some cool info! However they are biased toward that Shaeffers a little IMO. And that stuff looks nasty right out of the bottle (If that was right out of the bottle). I dont believe alot of stuff unless I do the test myself but who knows? I never use any additives anyway so..... :thumbs:
We've put lucas in all of our 18's and mechanic's work trucks because they are all high mileage and they have improved the life of the trucks dramactically
Personally, I don't believe in additives. I have heard some pretty good things about lucas though. Some people swear by it.
I think we are sponsored by Lucas lol we keep a few cases in stock.
My dad's work truck has 250K on it for a 97 hardbody and it doesn't use a drop of oil between changes
Oh buddy, I've been over on Bobs site for a while reading posts on Lucas Heavy Duty Oil Stabilizer and I'm more confused than ever! :confused:
There are just too many choices out there nowadays to know what's good and what's not. :confused:
I didn't really believe that test because he's taking small ass gears and trying to convince people that the same will happen in rear ends or the motor when the conditions are never going to be the same.. I want to see him do the test with one of our 60 bogie rear ends then maybe I'll consider believing him.
    B07
    B07
  • Who's Online   0 Members, 1 Anonymous, 835 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
