Hello, exact same problem on 2012 5.3 avalanche with 170k.  Just did the DOD lifters incl. oil pump and drops below 20 at idle, runs at 20 on freeway at 1700 RPM.  Doing filter now, but anyone had any luck on this thread yet?  Going to 10w30 as well.
  • 3 months later...
Hi there,
I'm having the same problem. 2011 Chevy Silverado, 5.3 150k.
Dod delete (Comp)cam stage 2 .597
Ls7 Lifters
AMF oil galley plugs
Non-AMF Valley plate
Upgraded Rocker Arm Bearings
High Volume 18% Oil Pump
Camshaft Gear and GM Cam Bolt
Timing chain and Camshaft Plate
GM Oil Pressure Switch
Ac Delco Oil Filter
Mail Order Email Tune GREAT TUNER
The engine runs smooth with a little chop. But I have a ton and valve train noise on both banks. My rod and main bearings look great. I bore scoped the camshaft bearings; they looked good. My oil pressure at the filter is 45 psi cold and the same at the oil pressure switch, the oil pressure drops to 20 psi at idle warm. The valve train noise get worse has the Engine gets warm and with RPM. No misfires. I talked to my tuner thinking it maybe the VVT solenoid dumping oil pressure due to tune. Nope!
The only thing I can come up with is the camshaft bearings must have enough clearance that I'm dumping oil pressure at the cam besrimgs and my lifters are starving for oil.
I'm going to pull the valve covers back off and hang the coils up and run the engine to see if I have oil coming through the push rods. If there is no oil making it up to the rocker arms it has to be the camshaft bearings. Does this make sense??
  • 5 months later...
On 8/21/2021 at 10:14 PM, Johnnyblazed said:
Im having similar issue on 2007 envoy.denali 5.3l. I installed a new mellings high volume pump, with the higher pressure spring as well. Cold it runs beautiful, NEVER any noise regardless of pressure. I checked.pressure with mechanical gauge to.confirm my cluster wasnt bad as i was told the clusters do go bad as well and could generate a false condition so it is important to hook up a mechanical gauge, dont trust the dash gauge, or scanners due to the fact some.may read data from the dash. My performance engine guy and gm tech are suggesting worn cam bearings, while another guy i work with who does.all the engine rebuilding (im a transmission specialist) is suggesting to replace valley plate expeccialy due tonthe fact it is leaking from the rear side. If the gasket is to worn he said it may be leaking to much internally at the seals, at idle 0, stayed 0 while moving prior to oil pump upgrade but now it will increase once rpms are up until it gets even hotter before then it stays at 0 with the rpm increase. If you have afm/dod it may be worth a shot. Another engine guy that does High Performance Engine also suggested a different melling's pump that could possibly patch the problem he said it runs about 75 PSI cold and I would probably still hold 20 to 30 hot but I really do not want to change the oil pump again as it is incredibly difficult while keeping the oil pan on I did it once already and I do not want to do it again the 4 x 4 version is very labor-intensive to drop the pan on my Envoy I am going to try a new Valley plate and see what happens
I've noticed the same problem with my 2007 Silverado LT Ext. Cab 5.3L with 109,000 miles. At high RPM pressure is over 40lb, but at a idle at at stop light it drops to around 20lb or lower. When you get on it pressure goes way up. Doesn't make any noise at anytime. I think I'll try changing the oil pressure switch screen, seems like that's the culprit and it's the cheapest fix.
    • There would be one way of determining the quality of the factory oil although probably more than a typical oil lab test, and that would be to draw out some oil from a new truck and send a sample to a lab that could do a more elaborate test of the oil. The issue with too little oil in the diff may not be the lack of lubrication of the diff bearings and gears themselves ( although a lack of oil volume for cooling ) but the wheel bearings because at some point the oil would be too low to properly get onto the spinning axle or fed along the axle tube. That was the claim by the local dealer from a couple of trucks in recent years that had the wheel bearings fail and they figured from lack of sufficient oil due to a severe underfilled diff and some of the bearing material made its way to the diff and it got damaged as well so the axle housings were just replaced on warranty. But your right that if the diff is over filled by whatever margin that it causes more churning of the oil than is desirable and that is no good either and can cause a pinion seal to leak. Also old oil I believe can tend to loose some of its properties like antifoaming and another good reason to change the diff oil every so often.
    • I would be surprised if the diff's were not filled (with the cheapest gear lube) at the axle factory before being shipped to GM.  If you ever watched them building trucks they install the axles and all suspension parts with the frame upside down and then turn it over before its time to install the engine.     Too much gear lube in a axle can be worse than not enough especially with a lower quality GL where is get whipped up with entrained air (foam)  weakening its ability to lubricate.
    • This is the 6.6 gasser section of the forum, you should either delete or modify your previous post as it is misleading for anyone looking for factual information on their 6.6 gas engine.
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
    • He has his dad’s newer truck he’s put away. He has several old cars he rotates between him and his family. I’ve seen a restored square body and a SS Chevy truck he’s sometimes drives. He did raffle off a new suburban recently. As much as he is watched if he drove new stuff as a rule we’d know it. It would be fine by me. I don’t care what people prefer. I got one more new one in me. I’d rather my wife get one. I can’t get her out of the Genesis. Don’t tell anyone. I want her to get an electric truck. I want to put a generator in the back. Just because. She hasn’t bit yet.
