2015 UCA aluminum to steel
My drivers side balljoint is starting to get bad, my local dealer told me they have discontinued making the aluminum upper control arms and that the stamped steel is the only replacement. My concern is I've seen a few posts on them rubbing with anything over stock sized tires. I'm currently running 295/60R20 toyo mts with stock 20 inch snowflakes. I've I replace my current control with the one in the picture am I going to run into trouble? 4373d939a2506c31ba4079a4b914af8e.jpg
Sent from my SM-G960W using Tapatalk
Going to be EXTREMELY close to the tire and may contact at turning extremes.  I had the same problem until I lifted more.  Only one way to find out...
So running straight shouldn't be an issue?
I would guess that you will be in trouble. I couldn't run a 295 on my 2017 with snowflakes and SS arms. I wish you the best of luck sir.
Sent via Morse code
Sent via Morse code
So what if I just go with a moog replacement?
    appletrav
    appletrav
  • Who's Online   4 Members, 0 Anonymous, 482 Guests (See full list)
