Ben and J-ho
k1500chevy97
Whoop-de-f**king-doo. :rolleyes::thumbs:
same thing I said when my local news made it a huge headline...
wtf cares?? i mean whupta do.. boohoo.. cry me a nile river. a big deal over what?? a marriage that no one cared to begin with?
Yeah I was pissed, I was gonna go crash their wedding.......I'm such a big fan........now if I could only hear more about tom cruise that australian chick
:rolleyes::thumbs::thumbs::cheers::eek:
The only ones making a media circus out of it is the media. I could give two f*cks less! Both are fuggin douche bags that make sucka$$ movies anyway. Jiggly or what ever the hell it was called tanked as hopefully will the other one they filmed together that is coming out soon.
I think Ben needs to head over to Home Depot and pick up a set of balls personally! No Man with red blood flowing through his veins and any amoutn of testosterone would create stupid gay a$$ movie like jigli.
But just so you know, this is CMNT's editorial and does not reflect the managements opinions. :rolleyes:
It may not reflect managements opinion, but it sure as hell reflects mine! :thumbs:
Like I said a few posts ago, I don't really care about the whole Bennifer ordeal. However, do any of you think that this may be just a publicity stunt to get the media off of their backs so that they can get married in peace without a million reporters standing around taking a zillion photographs? Don't get me wrong, I hate both of them just as much as you do. I think they are horrible actors, make crappy movies, and frankly wouldn't give a flip if they both disappeared to some deserted island and didn't ever make another movie again. But, still, you have to wonder.
d**n movie stars (or people who think they are!).
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,047 Guests (See full list)
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
