No Sound coming from the Radio - 2015 GMC Sierra 5.3L
GMJared
Hi all,
So, as the title says, I have no sound coming from the speakers in my truck. No blinker noise, no door charm.
It first starting cutting out during a phone call through blue tooth audio... it sounded like something was shorting out. There was a beat to it.
I noticed it would increase at stop lights, when the break pedal was compressed?
After youtubing soloutions, I pulled the RDO fuse, this did not solve the "shorting" sound that would cut in and out. So I tried disconnecting the battery, this also did not work. Ive also checked G218 grounds.
Now there is no sound whatsoever and it has been a couple weeks.
I have contacted multiple dealerships and they have told me that they do not touch anything todo with the Radio, and have to call in a specialist. So, I came here for help first!
thanks in advance for any troubleshooting advice!
Is this a Bose or non-Bose?
When I was installing a sub in my 15 w/Bose, the negative terminal on the battery that I disconnected wiggled itself back to the negative post on the battery.  When I plugged the Bose amp behind the rear seat in, it immediately sparked and blew a fuse, which I believe was something like AMP in the same panel where you found the RDO fuse (passenger side dash panel).  The result was no audio/chimes/etc but the 8" screen also went blank and didnt fire up the mylink either.
If you don't have a Bose system, I'd suspect the HMI module behind the glovebox (bluetooth in here, right? or is it the radio module?).  Otherwise, I'd have a look at the amp in a Bose configuration.
Thanks for your response!
I am going to replace the battery and see if this solves the problem.
My 15 doesn't have Bose, and when i had the glovebox out I could not located the HMI, I may not have been looking in the right place when i had it apart. I will check again if this battery replacement does not solve anything.
I appreciate the help ! Ill let you know how it goes.
HMI is almost vertically mounted I believe with a bunch of connectors in it.  Might be worth a shot to re-seat those as well if you're in there.  Above cabin filter.
But yes I'd start with the battery/cables/connections.  Low voltage in GM cars can do all sorts of weird things.  Any strange lights or codes showing up?
No codes or lights show up... I went and grabbed a battery today, no change. Proceeded to take out glove box, disconnected and reconnected HMI, still nothing..
I feel like its got to be right at the beginning of all speaker connections?
    CaptainDad
    CaptainDad
  • Who's Online   2 Members, 0 Anonymous, 545 Guests (See full list)
