Strange wheel weights
Just started full timing RVing - 5th wheel -to see the country I defended.  Did a Smart Weigh with Escapees. Weigh each wheel independently.  Chevy 2017 3500 HD. Winnebago 39FB 5th wheel. B&W Hitch is installed in GM factory pucks/holes.  Airlift Airbags Smart II System
Truck only individual wheel weights.
 Front Left 2850 Front Right  2750
 Rear Left 2300  Rear Right 2300   (Dually)
Pretty even unloaded. Weight in truck distributed evenly.
Truck and Trailer loaded
Front Left 3000 Front Right  2500
 Rear Left 3900  Rear Right 4600
Truck is cockeyed/unbalanced
500 lb heavy on Front Left
700 lbs Heavy on Rear Right
Logically if 5th wheel is putting weight on one side both front and back should be heavier on one side. If frame was bent it should show up when unloaded also.
Any thoughts?
Scales and weighmaster are certified. They weigh 20-30 times month
Any thoughts?
I have never towed a 5th wheel but my bro-in-law has towed a 5th wheel camper for years.  He said this about weighing by tire:
If your truck & trailer were on an angle the true weight will be off possibly due to the scales being higher than where rig is sitting.
Must have a level place to put all wheels while one is on the scales.
I don't know if this possibly could explain the differences you are seeing but I really didn't ask him about it in detail - just asked
what reason could there be for individual wheels on 5th wheel to have different weights on scale.
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 1,225 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
