I just ordered a new climate control unit for my 95 Chevy Silverado. Now that I received it, it doesn't appear to be an exact replacement. The fan connection seems to the only connection that fits. The new board does appear to have connections for the defrost or compressor. Does anyone have information or experience updating this unit?484ca0b3047dd2e6c58b39d85c895379.jpgfb5523b98e0b4888ca679868d6788119.jpgba49f010cf6859e358c385aca79871bc.jpg0519b5a4cde086b53d307e2a3fd3d9a2.jpg
Sent from my SM-N950U using Tapatalk
I'm also looking for a new climate control unit for a 95 k1500.  I don't need rear defrost. I'm having trouble confirming which part number I need.
ACDelco 15-72548
This part number above keeps coming up when I Google it. Seems to be a difference of opinion on whether or not it fits 95.
LMC has 89-94 and 96-99 available.
Does your new unit have a rear defrost button?
After some more reading I've discovered that there is an adapter harness that appears to bridge between the 96-99 climate control unit and the factory 95 harness. Looks like you have the 96-99 unit. The 95 units sold today are just a 96-99 unit with the harness attached.  Yours doesn't appear to have the harness.
Trying to locate the harness without the unit is difficult. I don't believe they sell just the harness any longer. You may be able to find a used one.
Looks like the options are
1. Find a used harness.
2. Buy the "95" unit which is actually the 96-99 unit with the harness attached. Link below. Notice the harness attched in the pics.
https://www.1aauto.com/1995-heater-and-a-c-control/i/achci00003?f=1023428&y=1995&utm_campaign=gb_csv_br&utm_content=HCI&gclid=Cj0KCQjwrJ7nBRD5ARIsAATMxssnXFBFeJHxqzlUZ_p9cCN-klFyQEkKwcTUTWLBJq1UvD8d3ssR4swaApqcEALw_wcB
  • 1 year later...
ACDelco 15-72548
https://www.ebay.com/itm/164534451465?hash=item264f047d09:g:kecAAOSwFiVgb2vn
https://www.ebay.com/itm/154210894266?hash=item23e7af81ba:g:8TEAAOSwBehgb20-
https://www.ebay.com/itm/184533101130?hash=item2af707aa4a:g:-6cAAOSwIwpfrXr~
https://www.ebay.com/itm/184533056336?hash=item2af706fb50:g:-6cAAOSwIwpfrXr~
HERE IS WIRE HARNESS ADAPTER TO USE 1996 - 1999 CLIMATE CONTROL IN TO YOUR 1995 TRUCK
https://www.ebay.com/itm/154210894266?fits=Year%3A1995|Make%3AGMC&hash=item23e7af81ba:g:8TEAAOSwBehgb20-
https://www.ebay.com/itm/184533101130?fits=Year%3A1995|Make%3AGMC&hash=item2af707aa4a:g:-6cAAOSwIwpfrXr~
https://www.ebay.com/itm/184533056336?fits=Year%3A1995|Make%3AGMC&hash=item2af706fb50:g:-6cAAOSwIwpfrXr~
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,003 Guests (See full list)
