Need Towing Mirror Info
I have a 2015 Silverado 2500HD with Duramax. I want to swap out mirrors for tow mirrors. I am having trouble finding out if my OEM wiring harness will work with factory tow mirrors. These will have all functions except auto extend. Need part numbers,etc.
When was your 2015 built?  Check the driver's door jamb, should have a month/year.  Important to know for 2015 model year HD on mirror swap.
Look in the glovebox for RPO AVF, if you have this, then truck was built after August 14, 2014.
With this RPO, you need harnesses. Without this RPO, you need harnesses and a jumper harness.
Dealer parts department should be able to use the vin to tell you what you need -- and quote the parts so you have something to compare to.
It was built after August. Thanks I'll check. With parts.
GM dealer quoted price of $1600.00 for pair. Totally outrageous. Will look for aftermarket mirrors.
Did you try contacting pgamboa who advertises on this forum. He has all the wire harnesses to hook up different towing mirrors and also has a contact for towing mirrors that won't break the bank. Good luck.
    Enduro73
    Enduro73
  • Who's Online   2 Members, 0 Anonymous, 1,713 Guests (See full list)
