2004 Silverado rear end noise
I have  2004 Silverado Z71.
    For about the last month, I have had a rotational noise coming from my rear end.
     It is only heard from 15-25 mph accelerating or decelerating, in drive or coasting (neutral).
 Doesn’t get better or worse when applying brakes.
   It sounds like a U joint. Kind of a swishing metallic sound.
   If you drive the truck for an extended time you will get a pop, that sounds like it is coming from under the bed.
    It will pop every hundred yards or so.
    The popping and the swishing noise will come and go.
    There is no vibration.
   I have replaced the u joints.
  I have removed the diff cover and inspected the carrier.  No metal flakes.
  I changed the diff oil.
When it makes the noise, hard rights make it stop, straight and hard lefts make it continue.
  Any thoughts?
