Cutting speaker openings
kaspar139
What do you use to CUT the openings in the doors to expand a speaker cutout? I don't have a dremel or a sawzall or anything. I was thinking of using my cordless drill with a metal file bit... That's all I got. Thoughts?
Thanks. :thumbs:
Use a dremel, sawzall, snips, or your drill with the right type bit.
There is no right way to do it, as long as it works for you.
Just take your time -whatever your method- and you should be fine. Just remember to ensure that there are no sharp edges before you start shoe-horning that speaker in there. Wouldn't want to ruin the new noisemakers.
Have fun!
  • 4 months later...
:cheers::cheers::rolleyes::eek::eek::smash::smash::smash::smash::smash::smash:
i used a plasma torch to cut out some of the door to fit 5.25 speakers in the 4x6 stock speaker hole. it made a clean cut and took probally 10-15 minutes to measure everything and cut out the hole.
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
