AM Radio noise problem.
2004 Sierra 4.8 SLE
Been having a am radio problem that is slowly getting worse. Decided to focus on symptoms a couple of weeks ago to rule out causes
( I have background in electronics and mechanical work and have installed a few radios over the years so figured it was time to solve this)
OEM stock radio with BOSE option
Symptoms
-FM fine
-AM short distance only
- engine noise is coming thru on AM only (low static)
- operating passenger window sends aoad whine through the System rhyme the driver window buzz is faint.
- have installed a couple of accessory USB ports. No change when they are uninstalled (they are wired to the rear cigarette lighter)
Figure there is a common ground between the window and radio. May have to put a power filter in. Anyone else run into this?
    mighty K20
    mighty K20
  • Who's Online   3 Members, 1 Anonymous, 621 Guests (See full list)
