Trailer brake plug
Just bought a 2018 Sierra 1500 SLE. It doesn't have the integrated brake controller so I need to install an aftermarket one. I looked up under the dash by the drivers side, but don't see an open plug like I was expecting. The only thing I see is the OBD2. Anyone have advice or pictures? Is there a plug on this model?
Black cover just to left of brake pedal. Pull it off and you'll see where the supplied harness plugs in
What he said.
Also, Your truck may have came with a long wiring harness connector made to connect aftermarket control to. My 2015 did and I installed own aftermarket. Video on YouTube to give idea of where
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,105 Guests (See full list)
