After Market Fuel Tanks
I'm assuming you are referring to the tanks that replace the original.  I preferred the poly because it was cheaper and added less weight.  Had a Titan on both a 2012 single rear wheel and a 2015 dually.  I installed both myself.  It was not easy but doable with some patience and a motorcycle lift to get the old one out and new one in.  The only problem I had with the tanks was some spit back when fueling.  I learned to shut off the pump as soon as I heard it nearing full and then squeezed in the rest a little at a time.  I would bet the previous year model tanks will not work on the 2020's.  Titan or any other manufacturer will probably have to get their hands on a new truck to design a tank.  I would think it will be a while before you see one that works.
    Enduro73
    Enduro73
  • Who's Online   1 Member, 1 Anonymous, 963 Guests (See full list)
