driver information center
I checked all 3 fuse boxes both sides and under hood. Tested all fuses with test light and all fuses were good . I have less than 30k miles.
Radio volume and favorites buttons don't work and all buttons for DIC don't work, horn works and cruise works. I don't know what else to check so any help would be great.
  • 2 months later...
