Io6 swap
Hello i have been fighting with this io6 swap already $390 in dealer programming and $200 in a module. Will the 23443747 module work in my 2014 silverado originally a io4 screen dealer said it wont display the screen but it was showing my reverse camera and start up logo also theft locked before i had taken it to them. Any help will be great thank you guys!
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 499 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
