2014 Silverado sliding rear window recall
416smitty
I have a 2014 Silverado I took the truck in for the recall for the sliding rear window recall and they removed the fuse until they find a fix. I  turned on the heated seats today a little cool up here in Canada but they didn’t work I know the heated mirrors are on that fuse but would like to know if the heated seats are on that fuse as well.
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 1,389 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
