03 Sierra won't downshift into 1st gear after replacing ignition switch
I have a 2003 GMC Sierra 1500 which i replaced the ignition switch non. Now the truck won't downshift into 1st gear, and I believe it is because the lock cylinder and the ignition switch are not indexed correctly. Is a procedure which shows what position the gear on the switch should be in realtive to the lock cylinder?
