212 Degree Trans Oil Temp Ok?
2019 Chevy 1500 2.7l, 8speed crew cab transmission oil temp is operating at 205-212degrees (empty bed) on daily commute, is this normal? I’m driving in 100degree Texas heat on the highways, with some stop-and-go traffic....What are you guys operating at?
Normal...well....GM thinks so. My 6L80E use to run 225 F unloaded on such a day. A bit more up a long steep hill. I forget where the alarm is set. Something like 260 F. Thermostat on this particular transmission was 192 F but that is the start of the opening not the full open. Anyway. I neutered the thermostat and currently on a 100 F day it runs about 162 F. I like to keep mine under 180 F no matter what. That's me. Others will have input I'm sure. This topic has been beat pretty good.
