Same truck - NEW camera!
Z71
My first Digital SLR. LOVING IT! :fume:
Shot was taken coming out of work in full auto mode. Just pointed and shot.
EXIF Stats just for fun of the original picture:
Width : 3072 pixels
Height : 2048 pixels
Horizontal Resolution : 180 dpi
Vertical Resolution : 180 dpi
Bit Depth : 24
Frame Count : 1
Equipment : Canon
Camera Model : Canon EOS 10D
Color Representation : sRGB
Shutter Speed : 1/60 sec.
Lens Aperture : F/5.6
Focal Length : 28 mm
F-Number : F/5.6
Exposure Time : 1/60 sec.
ISO Speed : ISO-100
Metering Mode : Pattern
Exposure Compensation : 0 Step
Date Picture Taken : 10/3/2003 5:06 PM
97' GMC Z71
BFG All Terrains:285/75's on Discount Tire's wheels, 16x8 MB Motoring "Rocker".
No suspension or body lift. There is an occasional rub on the front fenders and I would like a 3" lift down the road. The only other thing that I may do is to put some nerf bars on the side.
97' GMC Z71
cool. looks Good. I've been debating 305/70/16's on an OBS or the 285/75/16's lately...those look good...but for me (at least for a bit) I'll probably have to stick with stock rims....oh and is that 20 or 35% tint on the front windows?
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,105 Guests (See full list)
