Taking the Dash off
Just watch out on the back of the trim there is little rubber boot type things the go on these plastic pieces they are pretty small and will come off if you are not careful. They are there to stop the plastic on plastic squeaking. It is very easy to take this trim piece off just follow the directions from above. :withstupid:
