Wheel fitment
WRW2018
I have a 2018 Silverado with a 4in BDS knuckle lift. My wheels are 20x9.5 with -18 offset and 4.5 backspace. I am trying to reduce my track width. I can get the same wheel but with a +6 offset and 5.5 backspace. I do not know the specs of stock 5 spoke 20s. Will either wheel fit without rubbing? Any advise is appreciated, thank you.
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
