Retained accessory power - which wire to tap into?
Vuk
I am looking to expand the OEM alarm system with shock and glass breakage sensors. Once I am done I will be posting details about my setup, but right now I am looking for the best place to tap into the RAP line - I need this to disable additional sensors when accessories are on (i.e., alarm is not operational). If someone has a better signal in mind (something that is directly related to the alarm, such as an "armed" signal), that would be awesome.
Thank you!
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 1,355 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
