Steering Wheel Controls
JE3_Yukon
The volume and station controls stopped working on my 2018 Yukon today. Trying to figure out if there is a quick fix. Anyone else come across this issue and could recommend a solution? Thanks!
These are the steering wheel controls.
Welcome to the site.
Anytime I have something like that happen, shut off the truck, open the drivers door, and remove key from ignition.
In most cases this will reset most of the electronics when you restart the vehicle.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,123 Guests (See full list)
