Fuse Block Corrosion 1996 GMC SIERRA K1500
IceInTheBack
I had a rebuilt transmission put in my truck and 800 miles later the check engine light comes on. P-1860, P 1864 & P 1886... All have to do with various electrical issues. Upon taking it back to Aamco, they found that the Interior fuse block was corroded and the fuse for the transmission was shooting back and forth from 00.03 volts to 20.00 volts. The trans will not do anything but use 2nd gear. It won't shift at all. Some of the gauges on the dash work intermittently off and on.
I am told that the fuse block needs to be changed, but that the wires could also be corroded also. I will not use Aamco any further, so the shop I generally take it to says they can change the block, but if the wiring harness is bad, they cannot get one other than maybe from a junkyard... That could cost me a fortune having them route and run a new harness and all the wires...
What are the chances the Fuse Block would be corroded and the wiring harness being ok?
Is what I am explaining typical when the fuse block goes bad? Electrical is my worse subject and it's like trying to understand Japanese spoken by a Russian. No offense to anyone... But you get my point, right?
I have more than $30k in this truck... I have replaced the Motor with a new crate motor, New Trans, New Entire Front end system, New Lift Kit, New Killer Stereo, New Brake system, new Wheels and tires, K&N CAI, New distributor, new fuel pump, new radiator and cooling system, entirely new A/C system, etc... I think you get the gist of what I have done... If not for the fuse block, everything in the truck would be new...
Any thoughts on what I might be dealing with?
Also, I have been unable to find any documentation as to how to remove and replace the fuse block and where the wires from it attach to??? Anyone know of some good documentation I can locate?
Thanks
    Bert 22
    Bert 22
  • Who's Online   2 Members, 0 Anonymous, 647 Guests (See full list)
    • Do you remember that Harley Davidson was more successful (solvent) when it produced about 60% of the market demand (by design) and forced wait times of up to three years? Even when your turn came around it was, "Take what we are giving you or move to the back of the line and start over". HUGE markup's were 'normalized' and dealer killed. 40% markup and no floor plan? What's not to love? Greed will kill them yet. They have surplus production and customer base is tanking. And still they think nosebleed pricing will work.
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
    • I can't believe that could possibly be the case. It should be 36mo/100k miles from installation. Then again, it also seems like since a dealership installed it, it'd all be in the system and you wouldn't need to worry about registering, either. Shows you what I know. 😄 Hope this one outlives the warranty!
