Actuator problem ??
I have a 04 GMC 2500 HD 4x4 Duramax 4 door. I can get air to blow thru the defrost and floor but not the vents for cab. Where is the actuator located for the vents or is there anything else I need to check.
Thanks.....
Jeff in Virginia
Blend motor  is on pass side under dash, just to the right of the hump. Could be the encoder on the motor or the blend door is stuck. I think A1A auto has a video on this on you tube.
    overspeed
    overspeed
  • Who's Online   1 Member, 0 Anonymous, 239 Guests (See full list)
