Would you mind sharing your maintenance regiment and what brands of oils you have been using. For example engine oil change intervals and the specific type and viscosity used, fuel filter intervals, ( engine coolant, is one that tends not to get changed often enough ) diff oil type and interval, transmission pan drops if that is how you refreshed a portion of the oil, transfer case and anything else you happen to think of.
By the way has the truck been on a lot of salty roads over these years and the first thing that shows up is the wax is gone on the frame from the rear of the transmission back and it isn't typically kind to brake life either which is why I was surprised how fantastic the brake pad life has been. Also if the park brake pads have been replaced as that has been discussed on here as per the rust belt area's cause the park brake shoe linings to fall right off.
sorry to bump an old thread, im a bit clueless with this stuff, would these fit a 2019+ Silverado? https://wiperpro.com.au/products/chevrolet-silverado-wiper-blades mainly wondering if the beam shape stays planted at highway speed, thats what seems to let the factory ones down imo
I have a 2018 Silverado Custom with 156k on the odometer. In the last month I've replaced the plugs, wires and the driver side engine mount. My wife just returned from a trip of about 1500 miles and told me the brakes are making a grinding noise when applied. I drove it and looked it over and this is what I found with the driver's side rear rotor.
I'm going to order new pads and check about having the rotor resurfaced. Hopefully this is easier than the last 2 jobs.
Peace
Any update if the new valve cover help with the oil consumption?
I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
