Creaking Steering Rack
dal1980
I have a 2014 SIlverado CC Z71 with about 58K miles, and recently developed a creaking in my steering.  I believe I have pin pointed it to the passenger side on the steering rack.  It appears to be coming from where the tie rod comes out of the rack.  Any one else had this issue?  I did a search on the forum and found a lot of popping and other threads from the rack and pinion but not his issue.  Any help is appreciated!  It creaks when turning both directions, no impact on the steering just annoying as hell, makes the truck sound like a POS. Thanks
I hope its just the inner tie rod. That's simple enough and cheap well you'd need an alignment afterwards. If its the rack you'd be in for 1k+ likely as I read afterward the dealer has to program it.
Sent from my LG-G710 using Tapatalk
After investigating further, I had a completely trashed upper ball joint on the passenger side.  I can only assume that was causing a bind somewhere in the front end that was causing the creaking sound.  When the wheel was up in the air with no load on it it was silent.  I make it a point to shake down the front end every time I rotate the tires which was done about 500 miles ago.  My plan was to order Cognito UCA's when i felt a bit of movement in the ball joints.  I didn't anticipate it going from no noticeable movement to a Holy S*&$ level of movement that quickly.  Either way, Cognito UCA's ordered and installed with no issue.  Hats off to those guys, sometimes aftermarket parts can take some massaging but these UCA's went on flawlessly per the instructions ( I know, what are instructions?).  Im back to a tight/ silent front end with better joint angles on my 2" level with the Cognito UCA's.
For what its worth, I have a total of 58k miles on the truck currently, about 35k of those are on a 2" leveling (lower spacer) kit.  That is with all stock Z71 components.
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,171 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
