Be proud Cub fans!
timk49
I've made some posts about Sosa and the cork that were not favorable to the him. Still, I feel bad for the Cub fans who have to be the most loyal baseball fans in the country. Wrigley field is packed every game with those fans when the team is winning and even when the team was in the basement. My hats off to the Cub fans. Congradualtions for a great season and good luck next year.
PS.
I sure hope my Padres wake up next year when they play in their new stadium
in downtown San Diego.
On another note too...... give the fan a break who grabbed the ball. We all would've done the same thing, it's a natural recation. I'm sure he wouldn't have done it if he knew it was going to screw something up.
Thanks. :thumbs:
As to that fan, yes it is a natural reaction, however when you see the left fielder coming, jumping and a chance to make the play, one can back off. it's not as Steve (the fan) was 15 rows up. He was sitting on the wall, the ball was coming to the wall, he was reaching over semi-INTO the field of play to get it and that's where Moises was. Do the math. This guy was also a local softball coach, so he should've known better right there, but let his emotions get to him. Being such a fan, being an opposing teams hit ball, had he even gotten it, he should've thrown it back as is customary when an opposing team player hits a homer in Wrigley.
This guy works (or worked now) at Hewitt Associates as a consutlant and a Notre Dame Grad, so he's not stupid either!
i agree, steve shouldve been more heads up. but we cant blame him for losing the series, stuff happens and a true world series team has to re-group and finish the series winners.
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 1,121 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
