NP246 Leak
Tahoe Owner
My first time on a forum so I hope someone can help. I have a 2004 Z71 Tahoe and my NP246 T-Case is leaking at the rear output shaft seal. My issue is the fill plug is stripped and I can’t remove it. Is it possible to add fluid thru the snap ring grommet hole until I’m able to get everything fixed and replaced?
The head is stripped (rounded). I had a mechanic do a service on it a few years ago and it appears he used an impact to tighten the plug. I’ve tried a pipe wrench, vice grips and every gimmick tool on the marker.
I had a stripped/rounded caliper bolt where vise grips did not work also. I used my hand grinder to flatten either side of head bolt and used an open head wrench which came out with ease.
    ar0517
    ar0517
  • Who's Online   4 Members, 0 Anonymous, 523 Guests (See full list)
