Mudflap removal help
I have a ‘14 Silverado and want to remove the factory mud flaps. I’m trying to find the stock pieces that go in the same place but the parts drawings are confusing. Are these the correct parts?
Front? Fender protector
Rear? Rear protector
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
