Which ones?
Vasa1
Will be buying new shoes for the 19 Sierra. Two choices. Either Duratracs or KO2’s. I’ve had BFG since ‘03 and they have been great, but considering Duratracs this time. So pls express ur opinions but on these two only. Mainly concerned for snow performance..
I know you said these two only but General ATX are 3MP rated.  I think any of these three are about the same. I did the research on all three and picked the generals just because they’re a little different than everybody else and have an extra layer of cushion.
For snow definitely the K02.  The duratracs are heavier and gave me worse mpg.  They also didnt do as well in snow.  I also tried the nitto ridge grapplers  and they were awful (for mileage and snow).
I am in the PNW so we have some pretty wet and slick snow that refreezes.  Results may very in colder drier snow conditions.
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 1,130 Guests (See full list)
