255/85x16 tires
Black02Silverado
Here it is again. I did a search to see if there is anything related to this topic as in this specific size tire and no results were found.
Is anyone out there running this size on there 1500 Silverado? It is a pretty tall tire at 33 inch tall. Even taller than the 285/75x16 that most are running. The trick is it is a thinner tire. So it would seem that it should fit since it is thinner but was wondering if anyone is running it. I want to get this size for my next tire purchase but it is hard to get anyone to let me put it on to see if it will fit before I buy. It isn't a common size so no one around here carries it and it will have to be ordered.
Thanks
I've got LT255/85-16s Cooper Discoverer STs on my 99 Silverado 1500 4x4. They fit without rubbing and I did not crank the t-bars. The tires fill up the wheel well nicely but they do look a little skinny from the front or rear. The only problem I found is that there aren't a lot of tires this size and the ones that are happen to be mud tires.
Steve
Thanks Steve, Now I can get those. They were the ones I was looking at. I wish the BFG's A/T's came in that size but only the mudders do.
How do you like the Coopers? Did you get a good price?
Thanks again :confused:
The Cooper STs are a decent tire, but, I haven't been able to go offroading since I got them and that was my main reason for picking them The tires are somewhere between an AT and an MT tire and much better than the stock Firestones I had. They do hum on the highway because they are pretty aggressive for a street tire but nothing I can't drown out with the radio. The ride is frimer with the larger tire which I definately like. The only other problem I had was the spare tire. I had an aftermarket hitch which I had to sell at a loss and then had to buy the factory hitch because the tire wouldn't fit under the truck with my old Drawtite.
I have about 25,000Kms and they still have lots of tread left, they are tough to find here in Canada but I got them for $190CDN installed etc. A BFG AT tire at 265/75-16 (one size smaller) goes for about $230CDN from what I remember.
Steve
Thanks Steve,
The price here in NC is $160 a tire. I'm looking at getting them next from what I have read, they are a good tire. I want a taller tire but not any thing wider. I figure that they are a 33 inch tire compared to the stock tires and the 285/75 x 16 tires. Not thrilled with outlined white letters but I can live with that. I figure I got 41k on the stock Firestones and will need the new tires by spring, so to start saving now. :confused:
    B07
    B07
  • Who's Online   0 Members, 0 Anonymous, 933 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
