04 Silverado Firewall Insulation coming apart
The firewall Insulation in my 04 Silverado is coming apart it has around 144k miles the insulation is getting into my AC system and clogging up my blower fan and might be causing issues for my Engine Air Intake is there any way to replace or repair it that is easy ?
I'd just remove it all or in that specific area so it stops causing an issue.
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 716 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
