fluid "like" noise in dash
Greetings,
I am new to this group and I have tried to search for an answer and I’m coming up empty. I have just purchased my first GM product: 1999 GMC Sierra 2500 ext cab 6.0L
The only problem I have found with my truck is that when you accelerate from a stop you hear a loud fluid like rushing sound in the dash. The sound is usually present in all driving conditions but at a lower level. I have tried to burp the antifreeze system with no effect and I’m now open to suggestions.
Thanks for your help,
Mike Magee
quite a common problem actually
some of the new stiyle trucks have a coolant restrictor
in the heater hose quick connects just before the
heater core. the restrictor is what makes this noise
the fix is simply to removed the restrictor. the hard part
about it is disconnecting the quick connects. special tools
are required and even then they can be a real pain.
:confused:
Thanks for the information. I will contact my local dealer and see if they can remove the restrictor for me.
Thanks again,
Mike
GUYS..........What you have is a bubble or air pocket in your
cooling system. My 97 did the same gurgle in the dash
thing. You have to "burp" the system. I did it by looseing
up the top rad. hose and burping out the air pocket.
These new GMs with NO rad. cap are a PIA !....geo
What was your exact procedure?
Thanks,
Mike Magee
this would be worth a shot: :thumbs:
Draining and Filling Cooling System
Caution
With a pressurized cooling system, the coolant temperature in the radiator can be considerably higher than the boiling point of the solution at atmospheric pressure. Removal of the surge tank cap, while the cooling system is hot and under high pressure, causes the solution to boil instantaneously with explosive force. This will cause the solution to spew out over the engine, the fenders, and the person removing the cap. Serious bodily injury may result.
Notice
When adding coolant, use DEX-COOL® coolant. If silicated coolant is added to the system, premature engine, heater core or radiator corrosion may result. In addition, the engine coolant will require change sooner-at 50 000 km (30,000 mi) or 24 months.
The following notice applies to the 4.8L, 5.3L, and the 6.0L engines only.
Notice
DO NOT use cooling system seal tabs, or similar compounds, unless otherwise instructed. The use of cooling system seal tabs, or similar compounds, may restrict coolant flow through the passages of the cooling system or the engine components. Restricted coolant flow may cause engine overheating and/or damage to the cooling system or the engine components/assembly.
Drain and Fill Procedure
Important
If you do not follow the procedure below, a low or high coolant level condition and/or vehicle damage could result.
Park the vehicle on a level surface.
Follow the steps below in order to remove the radiator surge tank fill cap:
Slowly rotate the cap counterclockwise.
Stop rotating and allow the hissing to stop.
After all hissing stops, continue turning counterclockwise in order to remove the cap.
STEP 3 ->Remove the drain hose from the left side of the radiator tank and repositon the hose to a catch pan.
Open the radiator drain cock.
Allow the system to drain completely.
Inspect the engine coolant:
Discolored -- follow the flush procedure below.
Normal in appearance -- Continue with the next step.
Close the radiator drain cock.
Important
When filling the cooling system use a 50 to 60 percent concentration with DEX-COOL® coolant.
Fill the system through the radiator surge tank opening.
Pre-mix a 50 to 60 percent solution of DEX-COOL® and clean, drinkable water.
Slowly add the pre-mixed solution to the system until the level is slighlty above the surge tank split line.
Start the engine.
Idle the engine for 1 minute.
Loosely install the surge tank cap. Do not allow the system to build pressure.
Cycle the engine from idle to 3000 RPM in 30 seconds intervals until the engine coolant reaches 99°C (210°F) and the thermostat opens.
Shut off the engine.
Refer to step 3 in order to remove the radiator surge tank cap.
Start the engine.
Idle the engine for 1 minute. Fill the surge tank to ½ inch above the COLD FULL mark on the radiator surge tank.
Install the radiator surge tank cap.
Cycle the RPM. Idle the engine to 3000 in 30 second intervals until the engine coolant reaches 99°C (210°F).
Top off the coolant, as necessary, to ½ inch above FULL COLD mark on the radiator surge tank.
Rinse away any excess coolant from the engine and the compartment.
Inspect the concentration of the coolant.
Flush Procedure
Important
Do not use a chemical flush.
Block the drive wheels.
Place the transmission in park (P) or neutral (N).
Engage the parking brake.
Run the engine until the thermostat opens.
Stop the engine.
Follow the drain and fill procedure using only clean drinkable water. Repeat the procedure if necessary, until the fluid is nearly colorless. Refer to the drain and fill procedure.
Fill the cooling system. Refer to the drain and fill procedure.
MIKE...I just loosend the upper rad. hose while hot and running.
Do this while cold tho!
Made sure to have a catch pan and the overflow bottle is full
with cap off. SURE a PIA and messy but cured the problem.
The air pocket just hissed out. BE CAREFUL THO !
Was SICK of the dealer BS ...CANNOT DUPLICATE!.....geo
It's snowing like crazy right now, and I'm going out of town for a couple of days. When I get back, I will burp the system. I will let you know what happens. I really appreciate your suggestions and they make sense.
Thanks again,
Mike Magee
AS..........SORRY.....Meant to say loosen the upper rad. hose while
COLD. Then run it up to when thermostat opens and hot flows!
Coolant will now run thru and hiss and drip some and "burp"
out the air pocket from the loose upper hose.
PIA, messy, and HOT....Use caution and face protection and
gloves etc !!!!!!
Its the only way I know how to do it !
Althought the factory procedure above might work for ya too!
..............geo
I was talking to my local dealer about this yesterday and the service manager said there is a restrictor plate that they add to slow the fluid down....
anyone hear this before?
    ballencd
    ballencd
  • Who's Online   2 Members, 0 Anonymous, 464 Guests (See full list)
