On 11/16/2020 at 11:40 AM, TA^Guy said:
I understand a diode only allows current to flow in one direction, is there a certain spec/size diode you recommend using?
I would love to do this to not only my fog lights so I can have them on with Hi-beams.   But I'd also like to run a jumper to the work lights on the mirrors to use them as ditch lights when needed.
I want to do this too. Task lights and hi-beams
    contrabombarde
    contrabombarde
  • Who's Online   0 Members, 0 Anonymous, 781 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
