2018 Colorado Tires with 1.25" Level
Hey all....Looking to put larger tires on my dads Colorado with a 1.25" leveling kit. Does anyone know what size we can go up to with out having any rubbing issues?
I believe the sock tires are 255-65-17's
Thanks!!
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
