Bye bye pontiac
tmf6902
I think chevy should pull to it should be
General Motors
Ford Motors
Daimler-Chrysler
That way it would really be a manufactures challenge since they want to keep all the cars the same anyways.
What will happen to IROC? They should run all monte carlo's or cts's
Maybe this is a sign of trying to improve there current line of cars.....
I'm a pontiac owner and I'm here to tell ya I like the 96-93 models a whole lot better then the current models. Plus Pontiac needs to get away from there plastic crap they use on the interior......
I kinda saw this coming when Gibbs left pontiac, I feel bad for the teams who switched to ponitac for this season that now have to change makes yet again.
What do you suppose this cost a team to change from 1 manufacture to another?
I don't know a cost but I know that's a lot of bodies to have to make and cars to reskin.
Actually it aint that hard now to reskin the car since they all follow the same pattern
you could knock off a couple in a day with no problem
They surely gave the current pontiac teams alot of notice to prepare for next year... :thumbs:
This was kind of a shocker. Usually we hear weeks if not months of speculation & rumors on a subject such as this before actual announcements are made. This was kinda "outta the blue".
Agreed. Bill Davis racing has raced Fords, Dodges, and Chevys this year with their 77 Jasper car driven by Dave Blaney. In the old days, the process to switch makes would be a bigger deal, but now it is mostly cosmetic changes. The teams who drive Pontiac shouldn't notice a huge difference, since Chevy is similar the Pontiacs. I think this is a smart move by GM, because they can focus on one car like Ford and Dodge.
    B07
    B07
  • Who's Online   2 Members, 0 Anonymous, 692 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
