285 45 22s really wide
Just received 285 45 22s. Sitting in garage awaiting day off so I can get installed. Measured unmounted and are 31.75 x 12". Didn't realize they were that wide. Supposed to be a little over 11". Will they narrow up a bit once mounted? I was considering going with a 305 45 22 instead but looks like these will be plenty wide already.
They don't look as wide once installed, here are 305/45 22's on my previous truck...171638ab690e41562393f1af7a6e7efb.jpg7d2dcb7d20d832c3dc68d9a544dc964f.jpg
