XPel instalers in MI
Just picked up a 2020 Silverado RST CC.  I tend to keep my vehicles for a long period of time like 10 years, traded in a 2010 HD2500, before that it was a 2000. Been doing the searching and researching and found some here in MIchigan.  I was wondering if anyone had it done in Michigan and if so which installer did you use ?  Were you happy with the outcome?  Cost would be great?  Did you do a partial, front end or full?  Did you also do the ceramic coating?  Pictures would be a plus.
Thanks in advance
Had Ziebart do my 2019 High Country. They did 1/3 of the front hood, front bumper, front fender plastic ends, 1/3 of the body panel behind the wheels, and the mirror caps. They cut their own patterns from their library of manufacturers and their pieces fit edge to edge instead of folding over the edges. [Pros and Cons for each I guess]. They always do a good job and this is the 4th vehicle done by them. About 1000.00. Also had their Ceramic coating applied to the entire vehicle.
X2 for norockchips.com. Clear Auto Bra.  Located in Plymouth, MI.
They applied ppf to my '16 Denali front end(18in back) and headlamps. Performed well, still looked great when I traded it in 2 mos ago. Haven't had a chance to get my new truck in yet.
    bellssn690
    bellssn690
  • Who's Online   3 Members, 0 Anonymous, 929 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
