2000 Silverado 2 inch suspension lift
2000 Silverado 2 inch or 3 inch suspension lift?
are they made?
I really dont need 4" lift
but I dont want a body lift!!!!
I want a suspension lift
Thanks
Yes, you can get the smaller 2" or 3" lift kits. Matter of fact I was talk'n to a local offroad shop about doing one on my truck this evening. They wanted $800 to install a Fabtech 3" suspension lift. That included labor. And I think a 3" body lift was around $650 or so. IMO a suspension kit is the way to go. Of course, a nice body lift usually compliments the suspension lift very nicely.
My question is this though....what are you trying to accomplish with the lift? If price isn't much different, then I might consider the bigger lift just for the fact you will have the extra clearance. I didn't check on a 4", just the 3" and 6".
Either way, good luck!! :D:lol:
PS - Is your truck a 2wd or 4wd?
Unfortunately, the shortest lift Fabtech has for 4x4s is a 6" lift.  The shorter ones are for 4x2s only.
Indeed the lifts I checked on was for a 2wd seeing how my truck is a 2wd. But it don't seem right that they would only offer a 6" for the 4x4's. I could be wrong, but it just don't seem right. :D
On the other hand, if all you want is a 2" lift and you do have a 4x4 then I guess you could crank the torsion bars up enough for the front and maybe use spacers or blocks in the back. I haven't checked yet to see who makes/sells them, but I'm sure someone does. And that would probably be a whole lot cheaper than a full blown lift. :lol:
Mine is a 4WD
I just want it up a bit to make my 285s look better
migt get 305s then
i just think the stock Z71 package is a llittle to low
    • $5.19 for regular...
    • My office is slowly filling with Blazer parts. Getting ready to do the big bang of repairs. Intake (second time), water pump, radiator, hoses, and I'm going to re-seal the timing cover where someone went hog wild with silicone. Might as well, because I don't think that's done right.   There's a local tow yard that I didn't realize also has quite the inventory of junk vehicles. This is an old school junkyard. No waivers. Cash only, you were never here if anyone asks. Don't piss off the owner, or you'll end up in the back of one of those cars, headed for the shredder. And if you see something, don't snitch. Cars stacked double high, wasps nests, trip hazards and junk everywhere. I found a few little odds/ends for my Blazer. The $20 I spent was worth the experience alone. But I was never there. What yard?   I officially love/hate this truck. It's so out of my wheelhouse, roughest vehicle I've ever owned. Every. single. repair. -is so hard-fought, everything that can go wrong, goes wrong. Currently in a hate phase, and kind of wish I was closer to sending it down the road with a lucky new owner, to be honest. Preparing for the day when I tear into this thing...lots of pre-funk with Ibuprofen.   Rock Auto sent me a bad reman rear wiper motor. It was a bear to install. The tailgate in these things has about eleventy-billion fastners and pieces and things that need to be uninstalled/moved just to access the shoddy rear wiper motor. The casing on mine was cracked clean through, btw. Nice, GM, nice. SO I got this new motor installed, hit the switch, I see it wig-wag (without the arm installed) and think I'm golden. Reassemble everything. With the wiper arm installed I gave it one final test. Time to clean up and take the other half out to dinner, collect a paycheck, right?   Nope. I hear the plastic worm gear stripping as the arm hung up. Just like my broken motor. Weak/old and shredding itself internally. I can assist the arm and the range of motion is normal, and it parks correctly. It just doesn't have the poop to actually sweep the arm with a blade on it. Oh, hell. Turned the key off and shut the shop door behind me. I get to do that over again, too.
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
