Reduced engine power p1515 p1516
Keeps giving me those codes . I have a code scanner plugged in always so I can press and delete codes to continue driving about 35 times daily.. eventually I have to pull over and shut truck off and then restart  to continue driving when it says reduced engine power without check engine light. Which usually happens  within a exact distance every time .
Needs throttle body connector. GM will sell you the kit you need it’s a connector with 8 wires hanging off of it. SOLDER THE WIRES. You’re welcome!
