Leveling kit
Hey guys I’m new to this but figured I’d hop on and ask a few questions. I’m just curious I got a 2016 Silverado. I’m going to be putting Motofabs 3 inch leveling kit on, but I also got ready lifts tubular upper control arms. Was curious if I was going to run into any rubbing or scrubbing with the new wheels I just picked up. Got the Fuel Maverick 20x10 -24 offset with Atturo Trail Blade MT 33X12.5R20LT. Wanted to see what y’all thought.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
