Corsa Exhaust
Anyone using A Corsa Exhaust...2015 Chevy 2500HD 6.0-Extended Cab..Thinking About Purchasing One.. (Corsa#14792)..They Only List It Up To A 2014...Should Be The Same..?
Purchased For 2 Corvettes Prior...And The Sound and Build Quality Were 2nd To None..
It took me longer than it should have to find it but this should interest you.  I am not really sure how to copy the link but one of these should get you there.  It's posted in the "tech" thread.  Your post is in the "mods" thread.  Good luck.  FYI, it sounds great and if I upgrade I will be going this route most likely.  There is good content on YouTube if you haven't found it yet.  I would probably go for the single outlet but either look good.
2016 Silverado 2500 6.0 with Corsa
By SOTO3389, April 13, 2018 in 6.6L (LML/L5P) & 6.0L (L96/LC8) Tech
For Anyone Wondering..Added A Corsa Exhaust ( Part# 14792) To The 2015 2500 6.0 - Extended Cab, 144" Wheel Base...  Its Sounds and Looks Great..No Drone..Fitment was right On...
I did my 2015 HD regular cab when I had it and got the Corsa system for it.  Same thing with the year range 2011-2014 but it fit non issue.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   1 Member, 0 Anonymous, 1,132 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
