Help needed with rim and tire sizing
I'm running a 20x9+1 on 275-60r20 no level kit with no problems. As long as it clears the caliper.
Sent from my SM-N975U using Tapatalk
    • *Your
    • I'd guess that it's because they are Mann-Hummel filters since about 2016, they own Wix and are mostly all made in China now.
