2008 5.3 silverado
Hi everyone,  i'm new to the forum but not to mechanics, where do i begin. I have a 2008 5.3 AFM (always F&*^(&^ malfunctioning) here's where I'm at and I'll try to be as detailed as possible,  It all started with another collapsed afm lifter ( i had had previously changed the AFM liters when i got the truck and ran great for years)   and up until this point used very little oil,  so i purchased a lifter kit and that included a new VLOM. all new lifters including afm lifters and lifter guides, all new gaskets/head bolts etc...I replaced the oil pump also with a high volume pump/o-ring and primed it, did the valve cover (pcv side) update too! I got the oil pressure up started it up and it  sounded great ran smooth, i noticed blue smoke immediately but it cleared off, after it got halfway up to temp the low oil pressure light came on so i shut the engine off. changed the filter (the filter i used was a mobile 1 filter) ran about 50 miles then same thing happened, low oil pressure light shut off engine and there was an excessive smoke from the exhaust . i shut it off restarted and the oil light went out but there was an excessive amount of blue smoke when i restarted it (i'm sure it's oil because the coolant hasn't moved)  but the oil consumption during those 50 miles was more than a quart and the intake had a puddle of oil when i looked in the plenum and was running rough. i wiped the oil out the next day and unhooked the pcv from the drivers side valve cover and blocked the hose off that goes to the top of the intake but left the valve cover end open, the motor stopped smoking immediately and the cylinders cleared out and started running smooth again but the low iol pressure warning cam back on. the oil Pressure sensor in the vlom is new also, the screen was temp removed but made no difference however the low oil pressure warning came back on, i changed the oil same thing low oil pressure warning . this was a very smooth running engine and used very little oil. has 250k but the cylinders still had visible cross hatching. the only oil pressure component i have not changed (yet) is the pressure relief valve in the oil pan and i would rather not (i'm 55) Lol! but if someone here could let me know if they honestly think that is the issue I will drop the diff/steering rack and remove the pan to change the 10 dollar part!  I haven't done a compression test but that will happen today!  any help would be greatly appreciated and thanks in advance.
-Bigkev
    JohnRoy
    JohnRoy
  • Who's Online   4 Members, 0 Anonymous, 626 Guests (See full list)
    • Which one, the AT or AS?   Starfire is made by Cooper/Goodyear but at $85/tire I'd think I'd need to level-set my expectations that they may not even be round 😉 But you're saying they're decent?   I'm already into this thing $1506 in parts, fluids, etc. Totaled all my receipts today. $250 of that was replacing an EGR and MAP sensor that were probably fine, but I'm not going to return the parts since they've been installed. I'm cheap, but not that cheap. I use it, I keep it!   I may or may not make money if I sell the truck at this point, but, that wasn't really the point. And if I billed my time, I'd be hosed for real. My thought on the tires is I "might" put 1,000 miles on before selling it. I just don't want to put absolute junk on it, that doesn't do anyone any good. If the Solus solidly isn't junk, I'll definitely consider them.
    • I leave mine as is. I'm always a trip away from riding on unpaved roads. Dealer can clean it when they prep it after I trade it in for another new truck.
    • I have these on two vehicles and love them. Pepper is one of them 😉
    • 4WD. Far as I know it came stock with P's and not LT's. Definitely planning to put P's on it, but stock is a 109 XL load rating so I should probably stick within that guideline.   No rebates on anything I can see at the moment. Discount Tire is offering $50 off, but Pep Boys is very competitive on price, and also carries all the off-brand stuff. Les Schwab always wants an arm/leg, but they do good work.   It still has the original spare. Goodyear Wrangler RT/S, thing looks like a tractor tire LOL!! How times have changed.
    • 2020 Sierra 2500 HD (base model) gas engine 4wd.    All 4 windows roll down on their own. Happens somewhat randomly after stop and engine off - when engine turned off, when walking away from vehicle before or after locks activated. Pulled the window fuse F14 Instrument Panel Fuse Block Right; the driver's side still activates from driver's side door panel; passenger and back seat windows activate from local switches on their doors but not from driver's side group of switches. Power mirrors don't activate with fuse removed either (same fuse for both circuits). Problem not solved.    How can they even activate with fuse removed but they are all still opening and can control from each door?  When they open on their own, I can shut them from the switch in each door, but they don't stay closed.    Seems to be activated somehow with key fob; something bumping the key fob in my pocket or just handling - removed key fob and took it far enough away and now the windows stay closed. Replaced key fob batty just in case, no change.    Sounds like some kind of wiring short or maybe electronics. Dealer will first replace electronic control module without checking anything else and I anticipate problem will still exist since their troubleshooting skills are limited to "do whatever the computer says".  In any case, keyfob seems to be activating the circuitry.    Surely I'm not the only one with this issue, but I can't find anything related on the site. What do yall think?   JohnRoy
