Hello
I just repared my 2500hd 2017 silverado 6.6 diesel duramax. This is water/flood accident car and electrical issues have...
I have diagnostic tool GM mdi, message is chassis control module is not detected. How can I find that module? I just remove spare tire and found two module. But part number tell those are brake control and Fuel pump modules..
Could you help me, how I can find it...
Tks!
BR. Jussi
  • 5 months later...
