Manual to Auto AC controls
I'm not a HVAC guy by no means but with the auto system there are other sensors and regulators throughout the cab to keep the temperature equal or different. My guess is these units would have to be upgraded along with the head unit for the auto to fully function. The auto climate was a $195 option but I imagine the head unit would cost close to that in the aftermarket plus all the time screwin' around rippin' the cab apart.
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
